define printable CD/DVD area
fiddlermaker
When printing Verbatim printable DVDs with my Canon MG7120 using Windows 7, I get a message that the material in the file to be printed is outside the printable area on the DVD. When I bypass that message, the printer puts ink on the outer rim of the DVD and also on the clear area around the hole in the center of the DVD. How is the "printable area" on "Disk tray J" defined, and what are the dimensions? My work-around is to manually remove portions of the images to be printed to avoid these areas, but it seems that a more robust solution is needed to prevent wet ink where it doesn't belong in the printer, tray, and on the DVD. Thanks in advance.
0 REPLIES 0
Friends and Family
