clear message code
mariericks
how do you clear a message code on a canon MG6220 -- code 6A81 got the jam when printing labels
1 REPLY 1
Julius
Rising Star
Hello mariericks!
This error can occur if there is a loose object stuck inside the printer.  Please try the following:
1.  With the cover of the printer open, unplug the power from the back of the printer or the wall.
2.  Look for any loose objects or packing material in the printer, clear if necessary.
3.  Try gently moving the ink tank holder as close to you as possible.  Try pushing the closest ink tank down.  Once clicked into place, try moving the ink tank holder closer, repeat as needed.  If you meet resistance, do not attempt to move the ink tank holder any further.
If the issue persists, please contact our support group using the "Contact Us" link below.
Friends and Family
