05-08-2019 07:22 AM
No matter what it always jams when trying to do double sided. This is a new printed, it works just fine when printing one sided and when scaning or photo copiing. it for some reason always jams for double sided
05-08-2019 10:06 AM
Check out this KB Article
Maybe the Transport Unit is not correctly aligned.
05-09-2019 01:59 AM - last edited on 05-09-2019 08:34 AM by Porcha
Hi aascaha,
I understand you have an MX532 and every time you perform two-sided printing the unit encounters a paper jam. To troubleshoot this issue I recommend performing several Roller Cleanings without paper and a roller cleaning with paper. The following steps will assist you:
Now, the roller cleaning process has been completed without paper. Next, perform it one time with paper.
After a successful Roller Cleaning process with paper, perform a test print of a two-sided document.
If the event persists, I would recommend troubleshooting with our support group to narrow down the cause of your issues. Please contact our support group at 1-800-OK-CANON (1-800-652-2666), Monday - Friday, 8:00 AM - 8:00 PM EST(excluding holidays).
09-11-2023 06:35 AM
I have a MF41bdw laser printer. It started jamming every time I attempted double-sided printing, suspiciously after using extra thick paper. I tried several times to fix the problem without success. I finally decided to take a really close look and discovered a thick piece of paper (an entire sheet) was jammed in the "runner" (my word) immediately above the paper tray. This "runner" is apparently only used when printing double-sided and, unfortunately, it does not have a jam sensor or detector to alert one to this problem. After removing the sheet of paper (there is a release lever) I could once again print double-sided. I hope this helps.
