10-12-2023
06:18 PM
06:20 PM
StevenMOD
The set-up software failed at about 99%. I went to the support and downloaded drivers from there and got it working. I added the printer through my laptop add a printer function and that worked. Next time I turned it on, no connection. I tried the connection features and the worked but then when I went back to the printer the next day. Nothing, no connection. I did a manual wifi connection today and it set up. (terrible screen and functions) Turned it off and came back later and no connection. The printer works great at printing, no complaint with that but what is going on with the wifi connection?
10-16-2023 04:18 PM
Thanks ArthurJ. I will keep the instructions for doing that in case I have some more problems with connectivity. Since I wrote that note I did a manual set-up to the router and it seems to be working like it should.
Thanks, Phil
10-16-2023 12:43 PM
If the printer is dropping from the network or is still connected but not being detected correctly, please click HERE for the steps to disable the ipv6 setting in the printer.
10-16-2023 04:18 PM
Thanks, Phil
01-26-2025 10:51 PM
Cannon used to be good name. But they’re putting out some trash now. Suggest getting HP or something similar
01-26-2025 10:52 PM
Just a trashy printer
