Windows 11 and PIXMA MG 3520
Annie220
I have an HP Pavilion and was recently forced to change to Windows 11.  My always dependable PIXMA MG 3520 refuses to print or scan, and the Canon website does not show a Windows 11 driver.  A friend who works in IT tried for 2 hours to install a driver, including using a USB cord.  We used the Canon website and you tube for instructions. The printer error lights blink 5 times and say they cannot find the cartridges, both of which are fairly new. I also replaced the black inkjet.
I should not be forced to buy a new printer.  This one has never failed.
Is there an easy-to-install Windows 11 driver?
The MG3520 is supported under windows 11.
I found a driver for it on the product's support portal.
Canon Support for PIXMA MG3520 | Canon U.S.A., Inc.
7 REPLIES 7
Moderator
Moderator
Thanks for letting us know what Canon product you've got. The PIXMA MG3520 is an older model which we have retired. While that means that Canon USA no longer offers direct support for it, your friends here in the Canon Community are welcome to offer suggestions!
You can also speak with a Canon Upgrade Program specialist to help you score a modern replacement that would meet your current needs at a discount. You can reach them weekdays and Saturdays at 1-866-443-8002.
Hope this helps!
I won't be buying another Canon because of the planned obsolescence.  A perfectly good printer will have to go to the dump.
And I am stuck with two inkjets (total $70+), one of which I opened while trying to solve the problem, so will not be returnable.
Thanks!  They could have marked it as the Windows 11 driver .....
I tried this several times with no success…got cannot detect printer…unplugged etc…what am I missing here??
madmaxxx
I had the same issue. The Canon Canada has the driver but when I tried it to set it up it would failed to detect the printer using Windows 11even though is supports it. After several attempts it failed, the only way I was successful was a program I bought called "Driver Easy" and the program found the drivers and installed it and now my Cannon MG3520 printer is back alive and working like it should. Now, I have it connected to my ASUS router to be network thru the house so my family can print from it. Good luck and hope this helped you out
