Very odd problem with Canon Pixma i4300 (color printing issue)
sharkys
My printer prints black text fine, including colorful illustrations. Also eg. test photo like http://printermaster.dk/TEST/Color_Print_Test.pdf are completely fine.
BUT - when I print real photography on Glossy photo paper, in approximately 1/3 of the picture I got aprox. 1 cm pinker/whiter stripe. I did all sort of cleaning, including removing and flushing print head and nothing helps. When I'm printing the same on the normal paper, I got stripes randomly in the picture - eg. 3 stripes / 3 cm long / 5mm wide. When I print without borders, the symptom again changes - the upper 3cm seems to be fine, then I can observe some horizontal lines, then again a pinker/whiter stripe and then the bottom seems to be again fine.
I did all sort of recalibration, printer head alignment, different sort of paper - the result is still the same.
Any idea please ? Is it time to throw it away ?
Also here are some results of the alignment, it looks very strange (vertical lines?!).
Head alligments / service info prints / etc. : http://s000.tinyupload.com/index.php?file_id=06883978457109160756
5 REPLIES 5
sharkys
I have also tried automatical alligment toggether with manual alligment of the printer head.
Btw, the catrigdes were replaced - no change.
Also have tried to disconnect printer shortly from power, reconnect, reinstalled drivers...
Here are some examples to better understand it :
- photography on normal paper - https://drive.google.com/file/d/0B0FHn7mFJP9PS1ZHZGRpSWNPVUU/view?usp=sharing
- on Glossy paper - https://drive.google.com/file/d/0B0FHn7mFJP9PS2ZCOW56ZTYwUTQ/view?usp=sharing
Really, no-one ? This isn't officiall support forum for CANON devices ? Man Frustrated
Hi sharksys!
Welcome to The Canon Forums, and thank you for your post!
We appreciate your participation, however we need to let you know that the Canon Community Forums are hosted and moderated within the United States by Canon USA. We are only able to provide support for Canon products manufactured for and used within the US market.
If you live outside the United States, please click here and select your country or region for your support needs.
You're free to discuss Canon products sold outside of the United States, but please be aware that you will not receive support directly from Canon USA.
So OK, and...you would like to tell me, that the same products, even sold in two different regions, would have another troubleshooting ? ...don't even try that please.
Try to be brave and suggest some solution please, don't hide for non-sense statement.
