01-13-2017 12:11 AM
This is a new issue for a two year old printer. I am trying to print a document from Microsoft Word. Shapes will print, but the text doesn't.
01-13-2017 08:49 AM
Hi DonaldBHarper,
To try and get the text to print, please remove and reseat the ink tanks and print head in the unit by following the steps located here. Once this has been done, please perform at least one cleaning and two deep cleanings on the unit by following the steps located here.
Should you continue to experience difficulty, we ask that you please contact a Canon technical support representative here for further assistance. A representative will be happy to assist you free of charge.
01-13-2017 08:49 AM
Hi DonaldBHarper,
01-31-2017 10:42 AM
01-31-2017 11:36 AM
Hi DonaldBHarper,
A test of your PIXMA MG5420 should be performed. This will tell us if the printer is working correctly. To do this, please load letter-sized paper in the PIXMA MG5420 and follow these steps:
1. Press <HOME> on your PIXMA MG5420.
2. Select Maintenance and press <OK>.
3. Press <OK> on Print nozzle check pattern.
4. Press <OK> on Yes.
The Nozzle Check will print. Please compare your printout to the example that has been attached to the bottom of this post. If they differ, please perform a few printhead cleanings.
To perform cleanings, please follow these steps:
3. Press <OK> on Cleaning.
5. Press <OK> on Yes.
After a few cleanings, please print another Nozzle Check.
Does the Nozzle Check print correctly? If not, it is recommended that you contact one of Canon's Technical Support Representatives. To contact a Technical Support Representative, please use the link below:
http://Canon.us/ContactLI
