01-10-2019 09:49 AM
I have a Pixma G-2000, but I suspect this occurs with any bottle printer. My experience with having to deep clean twice tells me I am using a lot of ink, so it's cheaper to just print something frequently. How often is enough to avoid deep cleaning?
01-10-2019 02:35 PM
Hi thailen,
I would recommend printing a black and white document and something with color once at month at a minimum. This way all the inks are being used but not as much ink as a deep cleaning would use.
Does this help resolve the issue described? If so, please click the Accept as Solution button so that others may find the answer as well.
01-10-2019 02:35 PM
Hi thailen,
