01-20-2024 05:18 PM - edited 03-13-2024 09:32 PM
(My latest Reply on 2/20 is important, so if you're new on this one, please read it too)
Can I have expert help with my barely ever used, home Canon Pixma MX922's black printing?
My home printer that I’ve barely ever used except occasionally has suddenly started printing the Black bad. It goes back & forth between printing perfect & then printing too dim every few lines. On the attached email that I just printed after working for hours to fix it, it oddly printed the first line dim, then it still prints every 4th and 5th line dimmer than the 3 lines between them. (see image below but maybe it's gotten a little better than it was? It's been terrible before) I've spent hours trying everything possible. I'm about to give up and buy a new, inexpensive HP or Brother's multi-function but I'm here to see if I might get lucky with some help.
I’ve owned this thing since June of 2016 and it’s always worked fine.
Please don't reply unless you've had what I describe happen or have access to specific knowledge of this issue. I say that since I’m a little frustrated and I’ve tried all the simple, standard stuff.
The Print Nozzle Check Pattern shows mostly good up in the PGBK section at the top except for lines 5-8 that have some slightly weakly printed areas. Those lines are all completely printed but parts are dimly printed. (see image)
Also, same thing down at the bottom in the BK section. Starts out great for 1/3, then dims for 1/2, then is great the last 1/6th of the area. (see image).
I've done several of the built-in inkjet Cleaning and even a few Deep Cleanings and nothing has ever changed.
So, I bought a Printhead Cleaning Solution syringe kit and I've gone thru that several times on both the PGBK and BK inkjets after removing those cartridges (see my 20 steps in image).
First time I let it sit 30 minutes and reassembled things. NO BETTER
Next I did the Cleaner again, leaving it for 24 hours. NO BETTER
Then I once again ran it through the automated Cleaning, NO BETTER, then Deep Cleaning, NO BETTER!
I've included a printed email of my 20 fix it steps so that you can see how the printing varies in quality about every 3rd line. I'm no printer tech but that almost seems like an ink supply problem, not clogged jets. But I know nothing about how these work even though I'm pretty mechanically minded and have interest in technology.
I'm ready to chuck this thing. I've got 10 full, new cartridges that I bought in a 15-pack on Amazon for $19.98 a while back, but I can trash those too and go buy a HP or Brother's multi-function, even a monochrome B&W laser printer that has a big toner tank so it doesn't need the CONSTANT replacement of ink cartridges that these Canons do.
But, if I can get this Canon going myself pretty easily and soon, I'd do it. This stuff isn't worth taking anywhere to have it repaired. Everything is built to be thrown away and Subscription junk these days, like the color HP printers are with their Ink Subscriptions.
I'm no Subscription guy.
Maybe there's an inexpensive, current model Canon multi-function that uses the same cartridges, so I could use up what I've got?
If you know that, please tell me that too. But first let's fix my Pixma MX922. 🙄😉
#PixmaMX922
03-08-2024 12:31 PM
Thanks for joining the conversation, vankjeff!
This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, click HERE search our knowledge base or register your Canon gear HERE to access additional support options.
Thanks and have a great day!
03-13-2024 09:30 PM - edited 03-13-2024 09:31 PM
Can some other users please help me? I'm not knowledgeable enough about printers to just be trying stuff. There HAS to be others out there that can give me tips on what to do. My questions now are simple, so please someone help me:
1. If only the PGBK is Test Printing good or and only black text isn't hardly even readable, since the built in Clean and Deep Cleaning do nothing, should I try my syringe of Inkjet Cleaning Solution in only the PGBK hole after pulling that cartridge, or should I pull them all and put it in a of the round orifices? I ask since I don't know if each has its own inkjet under it or if they all might feed to the same one, in which case I'd think that maybe I've been goofing up by only pulling the PGBK and "cleaning" that one. The colors Test Print perfectly but the BK Test Prints with a little deficiency down the center. That's probably visible in the PrintScreen I've got in my original Question posting.
2. Can new canisters of ink go bad even if they've never been opened? I tried a new one that I had from Inkjetcorner and it has the same issue with not printing. I have another that I could try but I hate to open another one if there's no chance it's the fix. These cartridges have worked fine for me forever. That's why I tend to think I've got an inkjet problem.
03-16-2024 05:30 PM
This is what I'm seeing.
The MX922 is 10 yrs old
You've already stated you are not using Canon inks
You've tried, cleaning and flushing the printhead
After 10 years, it safe to say you have received a good return on your investment. Most PC's, mobile devices, and other peripherals don't make it that long. Those that do are probably pretty slow by todays standards.
Using 3rd party inks is not recommended. They can work like you said, until they don't, but most often they are not manufactured with quality and reliability in mind. Corners are usually cut and the parties producing them are more interested in profit over how well they actually work.
Printheads have a useable life. They are subjected to electrical current and heat during the course of their life. They can and do eventually wear out. No amount of cleaning can fix this.
Maybe there is another problem you are unaware of. You buy a new printhead and it doesn't solve the problem. You're out this $$$ which might have been better spent on a replacement device. My last printer made it about 11 years. I am not proud of that. I have 2 new Canon laser printers and am kicking myself for not buying them sooner. Everyone in the house is happier and I haven't had to help anyone, nor have they had to wait for me to come home to print something.
Realize your time is valuable. Whether you are retired or working, make every minute count. If you don't no one else will either.
Call a Canon Upgrade specialist. Tell them how much you liked your MX922 and what you are looking for in a printer now. If you print a lot of photos, a megatank might be a good option. If you print office type documents, then a laser printer would be great. 10 yrs is a good long life for any printer.
Canon Sales / Upgrade
Canon Upgrade Specialists at 1-866-443-8002
03-16-2024 06:00 PM - edited 03-16-2024 06:01 PM
Thanks Rick. I’m with you on everything. I’ve got my eyes on 2 different new printers, a mega tank and a laser. I don’t really need to print pictures, so color isn’t really a necessity, just a ‘probably should’.
One question though, since the Test Print only looks bad on the PGBK section and just a little weird on the BK one at the bottom, but the colors look great, wouldn’t that mean that the only problem is that those 2 cartridges that aren’t feeding their ink to the printhead properly and that the printhead itself is OK?
03-16-2024 10:33 PM
It likely means that the portion of the print head that uses those inks is failing. The print head consists of thousands of little nozzles but they are devoted to a particular ink channel.
03-16-2024 11:55 PM
Thanks JR. That tells me just enough. I’ve seen YouTube videos that show how to change a printhead and I’ve seen printheads for sale. I haven’t watched any of the videos but I am OK mechanically, just no electronics experience. Do you think I should try putting in a new one? Do you know if it takes any tricky disassembly that might be a challenge to a novice or do you think or know that it’s easily accessible? I’m a fixer type guy but if I should just get a new printer/scanner, I’m OK with that too. I just don’t like to give up. What do you think?
03-17-2024 06:32 AM
https://support.usa.canon.com/kb/index?page=content&id=ART143853
It's generally an easy process. I don’t know the specifics of your printer, but many come with the print head in a separate package and require installing the head as part of the setup process.
The path would depend on the cost of a new print head. With a new print head you would still have a multi- year old printer mechanism. A new printer comes with a complete set of inks, so there is some offset there.
03-17-2024 05:45 PM
Thanks. Here's the 2 I've been looking at:
1. Canon MegaTank G3270 All-in-One Wireless Inkjet Printer $149
2. Brother Compact Monochrome Laser Printer, HLL2395DW, Flatbed Copy & Scan, Wireless Printing, NFC with Refresh Subscription Free Trial $189
Those “ink subscriptions” seem totally stupid to me, especially as a home user.
I’ve had several Brother MFC-7820 (?) that I really liked. Monochrome, multi function with gigantic container of toner. Used them at home and in the real estate business I owned.
I can’t decide if I really want to bother with or even need color.
05-10-2024 05:45 PM
Heres a you tube video. https://www.youtube.com/watch?v=BLchquFrzpQ
I have successfully cleaned 3 heads on MX922's. I soaked - cleaned and I used my air compressor, safely. I am an ex HP Tech with proficiency in Laserjet commercial technology. So the nay-sayers can go away, unless they have equal service qualifications. It requires vigilance but the heads under MOST circumstances can be "blown out".
Steve B
