09-11-2017 01:04 AM
Hello forum! I am happy to find a forum where I can figure out my printer!
I would like to know why the printer used for a long time, the original or normal use, suddenly the printer light flashes, the printer does not work?
what is the reason? How should I fix it?
Hope someone can help me, thank you!
09-11-2017 01:58 AM
Ink jet printer has a waste ink pad, its role is to absorb the print head cleaning when the exhaust ink. The amount of ink consumed by each printer in different ways is different, and is controlled by the main board. The counter accumulates the amount of ink (i.e. waste ink) that is consumed every time the head is washed. When the cumulative amount of waste ink reaches the upper limit, the printer will stop working and prevent the ink from being filled with ink. The ink will drip into the printer and damage the printer.:smileytongue:
09-11-2017 01:58 AM
09-11-2017 02:20 AM
If your printing is particularly large, note that the printer may use the 20 cartridge, and the printer might have this problem. If such a problem occurs, it is better to send the printer to the service station, replace a new waste ink pad and reset the waste ink counter.
09-11-2017 03:36 AM
I have been through the detection of fault to no avail.
09-11-2017 10:40 PM
There may be a foreign body inside your machine
09-12-2017 12:03 AM
What should i do?
09-18-2017 03:41 PM
Hi! I have a pixma mg2922 and windows 10. It has been working well, but just recently it just prints very small and in the upper left corner of the sheet. I probably did something but have no idea what.
09-19-2017 06:24 AM
Hi Bob87,
It is recommended that you contact one of Canon's Technical Support Representatives. To contact a Technical Support Representative, please use the link below:
http://Canon.us/ContactLI
