TS9520 Paper return comes out the back
DEBM
I did a bad thing and loaded sticker paper in the cassette that was too heavy! It fed in then started making an awful racket and whirling sound until it jammed.
Now when I try to print it does not print and it returns blank paper out from the back!
Error tells me there is not paper in the cassette, which there is
I looked around everywhere inside that I could for damage but found no broken pieces,
Is there a part I could order to repair this? or info on what to do? or am I going to have to get a new printer. I really liked this one but just can't afford to replace this model.
If I have to buy another printer which less expensive Cannon that uses the same ink ( 5 color cartridges) would you suggest?
Thank so much for your time and knowledge.
1 REPLY 1
ArthurJ
You would qualify for the Canon Upgrade Program. This is for out of warranty units which have been diagnosed to require service, or for some reason are incompatible with a new or upgraded system. This option allows you a one-time opportunity to purchase a replacement product, discounted from the list price.
If you would like to take advantage of this offer, please the Canon Sales Department at (866) 443-8002 Mon-Sat, 9 AM to 9pm EST excluding holidays.
Did this answer your question? Please click the Accept as Solution button so that others may find the answer as well.
