12-03-2018 06:25 PM
Simple question: How do I close the operation panel on my new TS9120 printer? The operation manual does not cover this, and I do not want to break it. The panel does not seem to want to be pushed down.
12-05-2018 09:02 AM
Hi drjensen58,
To close the operation panel you will first want to make sure the paper output tray is closed. Once the paper output tray if closed, you can push down on the operation panel to close it.
About halfway you may noticed some resistance. This is normal and if you keep pushing the panel down, it will close all the way.
12-05-2018 09:02 AM
Hi drjensen58,
02-19-2019 07:01 AM
This is a manual close, correct? The tray does not automatically retract?
03-26-2019 11:02 AM
04-01-2021 03:33 PM
