TS9020 Printing labels
mbnelsen
Please help! I need to print some labels. Can I use Avery? If so, what size labels work? If not, what other software works? I can't find a "label" setting,  nor a  cardstock setting. I am uploading my own design.
4 REPLIES 4
Printers (all of them) usually include general limited support for label printing.  To get more options, use a program like MS Word.  Word for example supports over 35 label stock vendors.  Avery is just one of them.
Select Mailings > Labels > Options from the program menu.  Once you select the vendor, you can select the label identifier (usually a number) that tells the software the dimensions of your labels.
James_C
Moderator
Moderator
Hi mbnelsen,
Avery can be used.  Please click HERE to launch an Avery link that will assist you further.
If you continue to have difficulties, please contact our support group using the following link:
http://Canon.us/ContactLI
Thanks, Rick. Can I still use my own design? When I tried using Word, it gave me limited stock label options.
These are cadid snaps I took at a wedding.  They can be turned into labels.  I didn't format them.  Just copy a paste. But you get the idea.
