TS8260 disc print tray
Elegant-Mess
For over 15 years I have been using Nero Cover Designer to print discs on Canon' disc trays, like type J.
TS8260 has a new type of multipurpose tray and I am unable to set paper size, disc position on the tray, etc. to set up a template so that the printer can print to the disc.  These can be set within the Nero "paper stocks" tab.
It requires to know paper size (tray size), Media type (prfintable disc) and paper source (Multi-purpose tray).
I then get an error message "The media type and paper size are not set correctly".
I think the media type is OK but nowhere is the 'paper' (tray) size to be found.
Can anyone manage to use this application and printer combination?  There would be other similar Canon printers in the TS range that would use the same multipurpose tray.
0 REPLIES 0
