07-19-2020 08:43 AM
Using MacOS Catalina (10.15.6) the TS8220 prints correctly, but attempting to scan gives "failed to open a connection to the device (-21345)". The TS8220 has current firmware (1.010), is in same room 3' from router and 8' from iMac, on same 2G network.The scanner previously worked before upgrade to Catalina.
Suggestions what else to try or is there already a solution?? Thank you!
08-25-2021 01:59 PM
Hi ptetreault,
What model printer do you own?
08-26-2021 07:57 AM
Canon mg5320
need to link to OS big sur
03-09-2022 01:33 PM
Since Mac's do not have a HOME MENU, your instructions are not relevant
06-09-2022 12:02 PM
This fix worked for me with my MacOS Catalina and a TR8620a. From what I gather reading these replies, either you need to enable IPV6 on your computer or turn it off on the printer.
06-12-2022 08:03 AM
This has just solved the same issue which I had with my new CanonTS8351A on MacOs Monterey. I followed the instructions to disable IPV6 and the scanning is now working fine. Thanks very much.
10-04-2022 07:18 PM
Made an account just to say this fixed my issue on macos 12.6
Thank you!
10-05-2022 01:25 PM
Worked for me - many thanks
10-05-2022 01:32 PM
The home button on the printer.
12-21-2022 09:19 PM
I'm from Latin America and then y did that.
I reboot my router and al WORKS.
Thanks Very Much
03-12-2023 05:19 AM
Thanks a lot for your suggestion. It worked fine for me (iMac (Retina 5K, 27-inch, Late 2014); macOS Big Sur 11.7.4).
