06-05-2018 05:56 PM
I have the printer set up to retract the tray upon power off in the eco mode. It says that depending on the angle of the control panel it may not retract. What is the angle supposed to be? When you print the panel automatically opens and the tray comes out. Without moving the panel angle it will not retract the tray when it powers down. I tried opening the panel all the way up and it still did not retract the tray. I tried closing the panel and it still did not retract the tray.
What angle does it need to be at????
If you print and do not move it then it should retract but it will not.
It appears that it does not matter what angle the control panel is in this functioin will not work.
I just bought it last week and it has the latestest firmware version.
06-14-2019 12:33 PM
Did the issue of the paper tray not retracting get resolved?
06-14-2019 12:34 PM
Did the printer tray not retracting ever get resolved,I have the same problem
08-27-2019 08:59 AM
I just bought the TS8220 and I can say that the issue has not been resolved. I checked the firmware and it says it has the latest version. As previously stated, the tray will auto-retract upon manually pushing the power button, but does not auto-rertact when it auto-power off. This is not a [huge] issue, but it's an advertised feature and iall advertised features should work. It's simply a bug in the code that needs to be fixed.
The only other anomally is what when scanning a document, it creates a temp image in the folder you have set as your destination. When you click Save As and give the document a name it saves that document in the folder with the name you wanted. That's all great...but it leaves the temp image there too. So, over time it will just eat up disks space unless you manaulyl delete them. This printer replaced a Canon MG6820 that used the Image Garden to so the scanning. That App worked great and did not leave the temp files in place.
Other than the two items above, I am very pleased with the printer.
11-07-2019 08:57 AM
First of all I'm also happy with the printer but as everyone else - cannot get the printer to auto retract the tray at the front and would like this to work.
Why have a feature and then cannot get anyone to make it work?
This topic is getting on a bit and it seems that Canon is not very helpful at all??
Why not admit or find a work around to get this to work?
Anything is better then just cheer silence - that is annoying and not helpful and puts peoples back up and gives very bad feeling and reviews that should not really be as they are good printers.
Hope this gets a definitive answer from someone from Canon please - so we can put this to bed.
