TS5120 installer claims I don't have admin privileges!
canonuser999
Hi so I run
win-ts5100-1_1-n_mcd.exe
and it unzips and places everything in Temp
but then after that it complains I must be logged in as adminisitrator.... I tried from an administrative account on a DOMAIN
3 REPLIES 3
Please open a command prompt and type the following:
>net users
press enter
What does the output show for your user account? (example)
C:\Users\admin>net users
User accounts for \\CORSAIR
admin                    Administrator            DefaultAccount
Guest                    WDAGUtilityAccount
The command completed successfully.
(example)
C:\Users\admin>net user admin
User name                    admin
Full Name
Comment
User's comment
Country/region code          000 (System Default)
Account active               Yes
Account expires              Never
Password last set            ‎4/‎9/‎2020 7:11:59 AM
Password expires             Never
Password changeable          ‎4/‎9/‎2020 7:11:59 AM
Password required            No
User may change password     Yes
Workstations allowed         All
Logon script
User profile
Home directory
Last logon                   ‎4/‎9/‎2020 6:53:41 AM
Logon hours allowed          All
Local Group Memberships      *Administrators
Global Group memberships     *None
Darius
Whiz
Hi canonuser999.
Newer versions of Windows will require you to, even when logged in as an admin, right-click the file and select Run as administrator.  You may also need to be logged in as a local admin, rather than a domain admin; the installation is developed for standard consumer use and not for deployment over a larger network setup.
Hi thanks very much for these instructions. The account is administrator privilege account.
The problem is that the installer doesn't accept users in the domain admin group to run the installer.
The solution -  (from my colleague) - is to log in as the local Administrator
