10-31-2023 01:32 PM
Out of the blue, I'm getting error message 2114 (paper mismatch) having to do with the rear tray , which I never use and is empty.
I have always used (2 years) the front cassete tray w/o problems until yesterday. I am wirelessly connected from my Chromebook. Can someone help???
11-01-2023 06:30 PM
I'm also having this problem. I'm trying to print a normal document on regular "Letter" paper and the printer is showing the Support Code 2114 error "The following paper is not loaded in the rear tray. Letter semi-gloss".
I have tried changing the input tray settings on the chromebook to "Primary Tray" but it didn't make a difference. I also changed the Color settings to "Black and white" without any luck.
Any ideas?
11-06-2023 11:04 PM
I am having this issue with Canon TS8320, which will only print to the rear tray and try to use Plus Semi Gloss paper, no matter what I do with my Chromebook.
I reported the problem to Google, with no response so far.
Also see this Google support thread https://support.google.com/chromebook/thread/241195485?hl=en
