04-19-2021 02:13 AM - edited 04-19-2021 02:15 AM
It pretty much as the title says. The Printer (TR7520) works perfectly fine except it won't print and stalls in the spooler till I run Windows Troubleshooter. Then it'll print like usual and the troubleshoot find no issue and then I'll close it till I need to print again. The Spooler does say "Attention Required" but no clue what attention is required. Hense me running the troubleshooter in the first place. Please advise. NOTE: The printer works perfectly and flawlessly with my Phone. (Note10+) And I get this same issue no matter what computer I try to print with. Oh, and the printer is set up as a network printer. Running Canon's MP Drivers ver 1.02 and up-to-date firmware. As far as I can tell, set up correctly.
Thank you for any advice to resolve this issue.
CL0v3
04-28-2021 01:53 PM
Hi CL0v3,
Please contact one of Canon's Technical Support Representatives via phone or chat. To contact a Technical Support Representative, please use the link below:
https://mycanon.usa.canon.com
04-28-2021 01:53 PM
Hi CL0v3,
