TR 7520 Copy
laoszak
I am unable to copy a Black and White Document.  I place the document on the platen, press the black button and a blank piece of paper is ejected.
4 REPLIES 4
Moderator
Moderator
Hi, laoszak!
So that the Community can help you better, please let us know if you're getting the same results when you try to print from a computer or mobile device. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
I CAN print a document from the PC and it will also scan a document.  It just doesnt print from the platen.
Any solution to why I cannot print a copy from the platen?  I can print from the PC.
Hi laoszak,
Please perform this test:
1.  Tap the gear icon at the bottom of the display of your PIXMA TR7520.
2.  Tap Maintenance.
3.  Tap Print nozzle check pattern.
4.  Tap Yes.
A test page will print.
Please compare yours to the example below.  Does yours match the example?
