11-09-2020 02:45 PM
How do I switch back and forth from printing in black and white to printing in color?
Anytime I press the "Color" button it just gives me an error saying, "The size of loaded paper is different from the print settings"
I haven't been able to find any help anywhere.
11-09-2020 03:12 PM
Welcome to the Canon forum!
So that the Community can help you better, we will need to know what model Canon
equipment you are using. Any other details you'd like to give will only help the Community better understand your issue. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE.
11-09-2020 03:15 PM
12-11-2020 03:31 PM
Hi dcouch93,
Please make sure that the paper type and size that you have loaded in your PIXMA MX492 matches the settings on your printer.
Please pull out the paper cassette and push it back in.
Press OK when this is displayed on your PIXMA MX492.
Use the left or right arrow to select the size of the paper that is in the cassette and press OK.
Use the left or right arrow to select the type of paper that is loaded in the cassette and press OK.
Once set, please attempt to print.
