07-26-2020 01:28 PM
I'm trying to set up my daughter's TR7520 for use in a college dorm. Everything works fine wirelessly, but she will not be able to connect the printer to the wireless network in her dorm. I can print from the computer using a USB cord, but I am unable to use the scanner.
I turned off wireless for both the printer and the computer. When I open the IJ Scanner Utility, the only device option is has is the scanner on the Network. Using that results in an error message that the scanner is offline. I've tried scanning from the printer's control panel. It gives me the option to scan to local USB. When I try to scan, it schows that it's working for a bit (although the platen light doesn't even turn on), then it finishes and I've got nothing on the computer.
By the way, I tried setting up Wireless Direct to the printer. I can connect to the printer in my wireless connections, but when I try to install the printer, it says it failed or it installs, but says there are no drivers available.
What am I doing wrong here?
07-26-2020 01:37 PM
Hello!
So that the Community can help you better, we will need to know which Computer Operating System you're using (Windows Vista/7/8/10 or macOS 10.x).
If you're in the United States, and this is an urgent support need, please click HERE to visit your My Canon Account to discover your personalized support options.
If you're outside of the USA, please click HERE to find support options in your country.
Thanks and have a great day!
07-26-2020 02:51 PM
