10-03-2015 11:09 PM
Is it still possible to scan an item to a Mac using the control panel on the printer (MG6320) when the computer is running El Capitan? If so, what utilities/drivers need to be downloaded? This used to work with the IJ Scan Utility, but I don't see it as a download for my printer. Thanks.
10-04-2015 03:01 AM
As I do not know the interface (USB/Wifi), I can only provide a partial answer. The IJ Scan Utility is bundled with the "Scanner Driver" available at the link below under the "Recommended Downloads" section. If you are using the printer wirelessly, you will also need the IJ Network tool, available in the "Software" section of the page.
10-04-2015 03:43 AM
Thanks, BHO52413! That did the trick. I only needed the updated scanner driver (specifically, the IJ Network Scanner Selector) to get this working over wifi. I very much appreciate the assistance.
