01-26-2017 12:53 AM
01-26-2017 10:38 AM
Hello.
When the printer is powering on, a brief cleaning cycle will be performed. Since the printer is used a few times daily, it would be fine to keep the printer powered on and reduce the amount of cleaning cycles that are performed.
We cannot recommend the use of third party or remanufactured ink tanks. They may cause print quality issues or lead to other errors.
01-26-2017 10:38 AM
Hello.
05-14-2017 04:59 PM
Hi everybody,
I am trying to hook up my new printer and don't even get past the "on" button! The message says to remove all tape (or whatever) which I have done completely. The only button lit is "copy"
HELP.
Debra
05-14-2017 07:10 PM
05-14-2017 07:11 PM
05-14-2017 09:17 PM
Thank you!
