03-26-2014 05:01 PM
I spent an entire day trying to solve the dreaded "Error code B200" issue. Finally, after trying 8 or 9 suggested remedies, the error was cleared and I had full use of the printer. Unfortunately, now the printer doesn't print! I then went through (again) all the maintenance options available: auto printhead alignment; manual printhead alignment; nozzlecleaning, etc, etc. The device just spits out blank paper! No matter what the image source, blank paper only on print attempts. I removed printhead, and gently blotted printhead surface with a lightly wetted paper towel, and produced a perfect ink pattern - magenta, cyan, black, yellow, and large black. So, ink is flowing, but software isn't talking to printhead to produce printed image. What up?
Printer: PIXMA MG892 aio
PC: Windows 7 64-bit
04-16-2014 03:26 PM
Hi the_hamster,
You mentioned that the nozzle check pattern printed correctly, but that ink does not appear on the page when printing from your computer; are you able to make a black and white or color copy successfully directly from the printer?
We look forward to hearing from you.
If this is a time-sensitive matter, additional support options are available at Contact Us.
