08-19-2013 09:37 AM
How do I know if I have installed the latest printer driver?
08-19-2013 09:58 AM
Hi Peewee!
So that the Community can help you better, we will need to know exactly what equipment and operating system you're using. Any other details you'd like to give will also help the Community better understand your issue. Thanks and we look forward to hearing back from you!
08-19-2013 04:25 PM
I have a Canon Printer PIXMA MX410 which I installed on 7/27/2012. About three weeks ago I started having problems with MS Office Word 2007. I been told to check to see if made be the printer drive needs to be updated. I see that there was an up date on 4/9/2013, don't know if I installed this update. How would I check or should I just install it any way? If I install it & it has been already installed what harm would be done?
08-30-2013 12:01 AM - edited 08-30-2013 12:02 AM
Hi!
To ensure the most accurate information is provided, please let us know the version of Windows in use.
If this is a time-sensitive matter, additional support options are available at Contact Us.
