03-06-2017 03:14 PM
On a page of hypertext and regular text, will print only hypertext- on other pages NOT containing hypertext it doesn't print at all merely spewing out blank paper. Any help appreciated
03-06-2017 03:29 PM
Will print only hypertext in a note but not its regular text. Will not print a page wth ordinary text, too. On a wireless local area network with two laptops, one running Windows 10, the other running Windows 8.1
03-06-2017 03:34 PM
Hi chateau!
Thanks for posting in the Canon Forums!
To have a better understanding of your issue, please let everyone know what operating system (Windows Vista/7/8 or Mac OS). That way, community will be able to assist you with suggestions appropriate for your product.
If this is an urgent support need, please CLICK HERE to reach our friendly Technical Support Team.
03-07-2017 06:34 AM
Hi chateau,
A test of your PIXMA MG5520 should be performed. This will tell us if the printer is working correctly. To do this, please load letter-sized paper in the PIXMA MG5520 and follow these steps:
1. Select SETUP from the HOME screen of your PIXMA MG5520.
2. Rotate the menu to Maintenance and press <OK>.
3. Press <OK> on Print nozzle check pattern.
4. Press <OK> on Yes.
The Nozzle Check will print. Please compare your printout to the example that has been attached to the bottom of this post. If they differ, please perform a few printhead cleanings.
To perform cleanings, please follow these steps:
3. Press <OK> on Cleaning.
5. Press <OK> on Yes.
After a few cleanings, please print another Nozzle Check.
Does the Nozzle Check print correctly? If it does not, please contact our support group using the following link:
http://Canon.us/ContactLI
