02-18-2019 07:46 PM
The last time I changed the ink cartidges there was a loud crackling sound after I closed the cover. Didn't think it would cause any problems, and I don't know if that caused any problem to the printer. Today I tried to scan and got the following error:
Cannot scan for these reasons:
-Scanner is turned off
-(If using LAN connection) It is disconnected from LAN
-(If using wireless LAN connection) Signal strength is poor due to obstructions.
-Netowrk connection is prohibited by security software
-Different scanner on the network is selected
Please check and try again.
Click [Scanner Selection] if you want to select another scanner
Scanner driver will be closed
Code:5,157,61
I am using the USB cable to scan and print. It was working fine the last time. Today the printer didn't even scan,print, or copy. There was an error from the printing queue and when trying to make a copy it printed a blank page.
I changed some settings to my router but it should have been a problem because I disabled the LAN from the printer's device setup. I would prefer not to use the wireless feature.
How do I fix the printer and get it to print, scan, and copy?
02-22-2019 03:24 PM - edited 02-22-2019 03:25 PM
Hi DoYouKnow,
I recommend going into your control panel and then selecting "View Devices and Printers". From there remove any MX880 series icon listed and then restart you computer. Then go into Add or Remove programs and remove the MP Driver and MP Navigator that is listed. Once that is complete, restart the computer and unplug the usb cord from the printer.
Once the computer restarts, please click HERE and download the MX880 series MP Driver Ver. 1.02. After you select usb connection a message will appear to connect the usb. After the usb is connected, the install will continue and please check to see if Scanner Driver appears in the progress bar. Once the install is complete download and install MP Navigator EX Ver. 4.1.4 from the software tab on the same page.
02-18-2019 08:19 PM
02-19-2019 04:08 PM
What operating system are you currently using?
I am running Windows 7
Can you print a nozzle check pattern?
Yes. Pattern C C C M M M Y BK is printed with corresponding colors
Have you tried reinstalling your printer's drivers?
Yes. I downloaded the driver "MX880 series MP Driver Ver. 1.02 (Windows)" from the following link:
I have retried to scan but the same error exists. I didn't hear anything inside the printer sliding as opposed to when it was working, I could hear the ink cartridges or the scanner sliding back and forth. It just sits still and then the error comes up.
Hi DoYouKnow,
02-23-2019 02:46 PM
Hi ArthurJ,
OMG! (Oh My Goodness!). Thank you!
I was so worried I would have to buy another printer. Your solution worked. Before your suggestions, I did reinstall the driver but didn't choose the correct connection - usb cable in my case. However, I didn't uninstall and resinstall the Navigator. Your suggestions to do both worked.
My scanner was working before, but my laptop has had issues with hacking and that could have caused the corrupted driver and Navigator.
Thank you again. You're awesome.
03/02/2023: New Firmware Updates Are Available:
EOS R7 - Version 1.3.0EOS R10 - Version 1.3.02/07/2023: New product announcements!
