06-29-2020 09:20 AM
I have been trying to get my printer to do the auto alignment and cannot get the process to complete. It will print about half of the auto align page, and then it stops and gives me an error saying I need to turn it off. The light blinks yellow twice. I've read that means there is an issue with the paper being loaded incorrectly or jammed but there are no problems with the paper. I can print other test pages, nozzle cleaning pages, etc without issue and can print from my computer to the printer fine - it will print the full sheet, but it's not aligned properly.
I already replaced both ink cartridges, and also uninstalled the printer completely from my computer and reinstalled both drivers and the printer and still having this issue.
I tried to call Canon for help, but could not get through to anyone without registering the product. I have tried to register it but am not finding the serial number on it after looking everywhere. I purchased this new in 2012 which I realize it is getting older but since everything is still functioning beyond the alignment, I would like to continue to use it if possible. HELP!
06-29-2020 09:48 AM - edited 06-29-2020 09:52 AM
If you have performed:
All maintenance tasks (or tried)
Checked for proper loading alignment
Replaced inks
Tired using different paper
Ensured no obstructions exist
Replaced inks
Removed and reseated the print head
Uninstalled and reinstalled.. etc
and still cannot print, the device will likely require service.
A that point, it will likely be better to replace it from a cost perspective. The cost of shipping and repair will likely exceed the cost of replacement. Don't forget to factor in your time which is also valuable. Getting 8 yrs from any consumer printer is good by todays manufacturing standards. Not to mention the improvements which will have been made since its release many years ago.
I understand how you feel and hate to throw things away that work... but have been left behind due to technology improvements.. Unfortunately, that doesn't seem to be the case here.
06-29-2020 10:21 AM
Thank you!! I think the only thing i have not tried is removing and reseating the print head but i have no idea how to do that. I hate to throw this out since i just installed the new ink cartridges yesterday...ugh!!! $$$
06-29-2020 11:05 PM
Greetigs,
Check this as well.
https://support.usa.canon.com/kb/index?page=content&id=ART137582
06-30-2020 10:02 AM
@shadowsports wrote:Greetigs,
Check this as well.
Thank you so much for the suggestions!! i will give this a shot. 🙂
