05-31-2022 01:36 PM
Apparently there has been something Canon has updated today or over the weekend which has caused a variety of users to experience the exact same problem - printer decided to power off and won't power back up. You cannot tell me that it is just a coincidence that all of our hardware drivers crashed at the exact same time. I am not buying a new printer when mine worked fine a couple of days ago before Memorial Day weekend.
06-02-2022 09:37 PM
Just tried printing for the first time in a while and it wont stay on, turns on and then back off.
06-02-2022 09:52 PM
Have you tried removing it from your Wi-Fi network? It's shutting down as it tries to communicate on the Wi-Fi. Try to turn off your home Wi-Fi, turn on your printer and reset/remove the Wi-Fi settings on the printer. Check if you will be able to print locally via cable as it works for me... seems the issue of shutting down has something to do with communication to Wi-Fi. Canon needs to resolve this issue
06-03-2022 10:55 AM
If you want to be able to print over wifi, just follow my solution post. Change your DNS to .001 and BOOM!
06-02-2022
10:09 PM
10:26 PM
SamanthaW
SOLUTION: After a 1:57 hold time with Canon customer service.... I have the solution! (and that was 2 hours, not 2 minutes) If this is happening to you it is very easily fixed. [Removed per forum guidelines] Although I wish I could make up for my 2 + hours of time. The tech told me that when they walked into the office Tuesday morning, "the stuff had hit the fan" because this has affected many models and they don't know what caused it. Here is what you need to do to fix it:
Completely unplug your router and then turn on your printer (it won't stay on if your router is because of a linking problem with the router, that we are going to fix.) So this is the step-by-step for the MG6620 and probably those models with similar menus, but whatever model you have just try to get to your DNS Server Setup. That is where the setting is that needs manually changed. So for the MG6620:
On the menu swipe to Setup, then find Web Service Setup then DNS Server Setup. Select Manual. Press each set of numbers and change them all to 000 except the last set. That needs to be 001. So your DNS will look like this: 000.000.000.001 Click OK, then click No.
That's it. You should be good to print.
You are welcome! Too bad someone at Canon doesn't just post this somewhere. Would've save a lot of people a lot of headaches, I'm sure.
06-03-2022 06:03 AM
Thank you so much!!! It worked and I am back in business. I work 2 days a week from home and need to print because at my certain job location I do not have a printer. And I had just bought about a year supply of ink to spend down a grant budget. Didn’t want to see it go to waste. I did go buy another printer yesterday though - $150.00 but I guess I will submit and get reimbursed from work so I have one my location now.
Unbelievable that Canon has not posted anything.
06-04-2022 04:24 AM
Canon Maxify MB2320
Printer started power cycling when Canon screwed everyone else this past weekend. I took the DNS "Fix" and instead of doing all of the steps I only....
Printer bought in 02.2015 and have never installed a firmware update and whatever Canon did this weekend, it still affected mine
06-08-2022 11:00 PM
My printer will not turn on. I used it yesterday to print one page, and today it doesn't respond to power up. Unplugged and plugged back in. Turned off my laptop, router, and modem like some other threads suggest. Still nothing. Left unplugged for 30+ minutes and tried. Still nothing. One thread says to update firmware. How do you do that when the device doesn't power on? What's next Canon?
06-09-2022 06:37 AM
From Sheri99 above -
01-08-2023 11:12 AM
Thank you and Sheri, but this has not worked for me. Tried again today. All wifi is off in my home. The printer has been unplugged for months. It will not power on. I'll never buy anything from Canon ever again since they're offering no help on this. Thanks again for sharing.
06-26-2022 06:43 AM
Check you power cord. May be it is damage. If it is working fine replug the cord after 5 to 10 minutes. If printer turn on then it is working fine otherwise change the power cord.
