08-07-2020 03:23 PM
I was notified that I got a reply about this, but was unable to view the reply, so I deleted my original post, and am reposting.
I tried 4 times to get my new printer to install. It kept going from "printer detected" to "printer not detected, check connection". I tried every suggestion in the guide, as well as trying multiple USB ports and 2 different USB cables.
This is driving me nuts! Help!
05-07-2021 02:56 PM
As soon as I read this answer to 'drivers won't install", I knew it was the fix. Sure enough, it worked for me! I was about to give up and found this response when doing a search for the answer. Thanks!
05-10-2021 10:08 AM
I just thought I would chime in to confirm that Kryseli's fix absolutely worked 100%; I was shocked at how quickly it completed the installation process when I did it the "right" way! I was also disgusted at myself for not realizing this was the answer all on my own.
So, for some 2021 verification of this fix, here's a current response and a comment: I'm loving my Canon printer already! So simple to use!
08-09-2021 12:35 PM - edited 08-09-2021 12:37 PM
@Kryseli ----- You are AMAZING!!!! I spent the first entire day with my printer trying to get it set up!!! I was so fustrated... I'm so glad I found your reply because it worked like a CHARM!!! How the heck did you figure it out?!?!? It's PERFECT!!! Thanks SO MUCH!
Cheri'
08-09-2021 03:20 PM
Thanks!! I worked in IT in a library for a few years, and I just got this feeling... sometimes printers and drivers are extremely picky about the order you do things in. So I uninstalled everything and gave it a go and it worked!!
12-12-2021 07:06 PM
This! This works. Thank you!
12-12-2021 09:10 PM
I was just about ready to empty a full mag of 9mm into my MG2522 after failing to install the driver for hours. This comment saved me the legal troubles that would inevitably arise from such an action. Cheers dude.
01-23-2022 09:20 PM
So, this is really just a test to see who can follow directions? Hahahaha! I flunked that test, obviously. Thanks for your excellent help!
01-24-2022 04:48 PM
Isn't everything? And you're welcome.
02-08-2022 12:40 PM
Thank you so much for this post. I almost threw it in the trash, before I found your comment.
God bless you!
11-06-2022 07:19 PM
I'm going to try to return the printer to Walmart, even though I bought it online. Can I then just return it to any Walmart store?
