02-19-2021 11:02 AM
This printer was working great until a couple days ago when the black started to fade, and now it doesn't print black at all. I've tried all the cleaning and deep cleaning steps and nothing works. Please help!
02-19-2021 03:09 PM
Hi tempeashers,
Performing a system cleaning should resolve this issue. To do this, please follow these steps:
1. Please press the wrench and screwdriver button on your G6020
2. Repeatedly press the right arrow button to select Maintenance and press the OK
3. Press the right arrow button to select Ink Flush and then press the OK button
4. Choose All Colors, Color or BK and press OK
5. Check the displayed message and press OK button
6. Select Yes and then press OK button
7. Select Yes and then press OK button
This procesdure is also covered in the manual:
https://ij.manual.canon/ij/webmanual/Manual/All/G6000%20series/EN/NTR/ntr_h_01.html
Once complete, please attempt to print.
If you continue to have difficulties, please contact our support group using the following link:
https://mycanon.usa.canon.com
06-28-2021 08:32 PM
06-28-2021 08:41 PM
08-13-2021 04:07 PM
Hi canon4njm,
Please contact one of Canon's Technical Support Representatives via phone or chat. To contact a Technical Support Representative, please use the link below:
11-30-2022 02:36 PM
Did you get this issue resolved? The same thing has happened to me and I am getting the same error when trying to perform the ink flush
12-05-2022 05:05 PM
No, it did not resolve for me. The only way I can print black is to change the paper to High-Resolution paper. This is very disappointing and I will NEVER buy Canon again.
12-05-2022 06:08 PM
I ran the cleaning function, followed by a deep cleaning, and then the black ink came back. I don't print often, not sure if that's the reason but for now this fix is helping
03-22-2024 07:35 PM
U need to print EVERYDAY to prevent this issue and WASTING YOUR INK
02-15-2023 09:06 AM
I am having the same trouble. The only way to get the black to print is to do a deep clean and then it only works for about 2 pages. Is there any way to correct this?
