09-07-2022 05:31 PM
I'm a nooby here at Canon. Have been printing laserjet printed labels for use in 4 dram vials of alcohol (8.5x11 sheets of heavier white paper cut into small inserted labels). I'm a aquatic stonefly scientist that collects and preserves these aquatic insects. I want to try the G3200 printer filling it with India ink into the black reservoir.
Will this work?
Do I need to fill the 3 color reservoirs with the india ink? Or select black or gray in the windows print dialog?
09-08-2022 01:37 PM
Canon can only recommend using Canon genuine ink and only filling the ink tanks with the correct ink marked for each tank.
11-11-2024 01:55 PM
Were you able to print the labels using Indian ink? I'm looking for the same thing, to make labels for the herpetology collection.
Thanks
11-12-2024 02:35 PM
nope it destroyed the print heads and could not clean them so printer was recycled, sorry man
11-12-2024 07:21 PM
What did you want India ink to do that normal ink does not?
11-13-2024 07:28 AM
The labels we need to print are stored in alcohol or formaldehyde, and India ink is resistant.
