09-02-2014 05:36 PM
09-02-2014 05:46 PM
Hi!
To ensure the most accurate information is provided, we will need to know the version of Windows or Mac in use.
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help 24/7 via Email at http://bit.ly/EmailCanon or by phone at 1-800-OK-CANON (1-800-652-2666) weekdays between 10 AM and 10 PM ET (7 AM to 7 PM PT).
Thanks and have a great day!
09-02-2014 08:08 PM
09-24-2014 02:07 PM
Hi merlin,
You can adjust the size of what you are printing by following these steps:
1. Open the item you wish to print.
2. Click on File and then Print. If File is not visible, please press the <ALT> key on your keyboard.
3. Click Preferences. If this is not available, click Properties.
4. Click on the Page Setup tab.
5. Under Page Layout, select "Scaled".
6. Next to Scaling, increase the percentage to 150 or 200.
7. Click Apply and then OK.
Print the item.
01-10-2016 12:19 PM
I was experiencing a similar problem. There are several posts in various forums on the internet asking the same question. The problems are not related to printer setup in the applications your are printing from, or in the print settings on the computer. In the process of copying a document on my all in one, I accidentally pressed the Stop and Start buttons simultaneously, this resulted in my printer scaling down the print size by 50%. I tried downloading the manual but there was no information contained therein to resolve the issue. What I ended up doing was the following.
The document then printed 100% to scale. No other settings changes I made in both the printer settings and/or application print settings made any difference. Only after attempting the above procedure did print scaling return to default.
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
08/18/2023: Canon EOS R5 C training series is released.
