Paper does not fit in paper tray
niecy
I just received my PIXMA MG7120 and it seems as though my paper tray is too small.  No matter how much i try the width and length is not adequate to fit standard 8.5 x 11 paper.  The measurement of the tray sent to me is: 8" wide from paper guide to guide and 8" long from topof gray guide to bottomof black end/guide.  Do i have the wrong tray?  Obviously if i can't use the tray, i can't use the printer.  Help!
2 REPLIES 2
niecy
Case solved.  Duh, it was lare last night and i had it on the floor and did not see the lower tray underneath (how embarrassing).  Im off to completing my set up.
Crabface71
I was just going thru the same issue!!! I read nothing about two trays up front. Thank you for posting this! Problem solved 🙂
