PIXMA iX6820 Unwanted lines of ink droplets
patton428
I hope someone can help! I have a Canon ix-6820 photo printer. Each time I print, I get a line of small black dots along the bottom edge of the paper. I've tried cleaning the rollers and bottom plates but to no avail. I also cleaned the print heads and when I print the nozzle check, it prints clean and clear (with the exception of the line of black dots.) I have brand new full ink cartridges. Any other suggestions?
4 REPLIES 4
biggie
i have the same problem! how did you fix it?
DerrickL
Whiz
Whiz
https://youtu.be/FbsGLZgVcfE
Do not use water of any kind, denatured alcohol is the best print head and surrounding parts cleaner to use.
i tried this and it did not work, any other suggestions?
biggie
fixed it! the solution was one of these:
- changing the ink
- changing the setting to prevent paper abrasions
- realigning the nozzle
not sure which one but i tried all of these and it worked!
