01-03-2026
11:21 AM
11:23 AM
I'm getting some dark toner marks about 3/4" into, across my 8.3" wide panoramic prints.
Pixma iX6820: This began after one of the panoramic sheets didn't feed, and the toner for the job welled-up inside the printer. I've gone through all the nozzle, plate, and roller cleaning steps; and have made numerous subsequent prints, to no avail. Also, it only seems to happen when I'm using the 8.3" wide panorama paper.
01-04-2026 08:48 AM - edited 01-04-2026 08:53 AM
First off you are getting ink smudges not toner smudges. I suspect your paper path is dirty somewhere. This may help:
Dark ink marks on panoramic prints from the PIXMA iX6820 may indicate issues with the print head or clogged nozzles. Running a nozzle check and performing head cleaning can help resolve this problem.
Issue Overview
Dark ink marks on panoramic prints from the Canon PIXMA iX6820 can be caused by several factors, including print head issues, incorrect settings, or media type selection.
By following these steps, you should be able to address the issue of dark ink marks on your panoramic prints.
https://ij.manual.canon/ij/webmanual/Manual/M/iX6800%20series/EN/UG/ug_trouble1800.html
01-17-2026 03:35 PM
As the only sheets that were being affected were cut from rolls, I eventually realized that the problem was a result of abrasion due to paper curling. So relaxing the paper for a few days before printing, solved the problem.
