PIXMA TS6320 - Error 2114
buzzy1
Printer error 2114 won't allowing printing from computer. Error says "the following paper is not loaded in the rear tray, Letter. I do not know what this means. There is paper loaded.
6 REPLIES 6
Moderator
Moderator
Thanks for joining the conversation, buzzy1!
So that the Community can help you better, we need to know exactly which Canon printer model you're using. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
It is a TS6320
Hi buzzy1,
To resolve the 2114 error with your PIXMA TS6320, please follow the steps provided on this page:
https://ij.manual.canon/ij/webmanual/ErrorCode/TS6300%20series/EN/ERR/2114.html?ref=2114
Is there a similar answer for a TR 7020a?
MojoJomo
For me, on my TS 6420, the 2114 error code was resolved by searching the printer's menus to tell it exactly what paper was loaded. In my case, that was the 4"x6" Plus Glossy II setting, for 4"x6" photo paper. I would have thought the printer would auto-detect the size, but that's not the case. To get to this menu, click the OK button for
  1. Menu
  2. Copy Settings
  3. Click down arrow to select the paper type menu
  4. Select Rear Tray
  5. Next
  6. Supported Paper
  7. Remove any paper from the rear tray.
  8. Load desired paper in rear tray. Adjust guides. Close the feed slot cover.
  9. A new menu appears on the screen. Select Change.
  10. Select: 4x6, hit OK; Select Plus Glossy II, hit OK.
  11. Hit the return button.
You're ready to print.
