PIXMA TS3722 - only printing half size
Kristisprinkle
Good afternoon everyone.  I have a TS 3722 printer.  I must have inadvertently hit a wrong button on my printer.  When I try to print, it prints the document in the top, left-hand corner at half size.  What do I need to do to get my documents back to full page?
‘Thank you so much for any help.
4 REPLIES 4
dexman335
Mentor
Mentor
I'm more familiar with the imageCLASS platform than the PIXMA. I suspect that there is a way to reset the settings of the printer. If there indeed is, a default might be able to clear a bad setting if it is the cause of the problem. 🤔
Thank you for your help. I will try that
laryub61
I purchased online TS3722. I tried to print return shipping label.  Print on return was too large.  WHY?
Why, when I print the return shipping label, is it so large?  I can't fit it on the return envelope- too large
Hello!
Since your issue is different from the original post, I request that you please create your own thread. This will ensure the Community can assist you. If you need help learning how to post, click HERE.
Thanks!
