05-21-2023
10:07 PM
09:14 AM
Best printer that works with transparent film?? Please help me out
I want to get into cyanotype but don’t know the best printer to purchase that works with transparencies
05-21-2023 11:11 PM
Although transparencies aren't officially supported, you should be able to print on them without issues. ***Make sure you buy the ones specific for your printer inkjet or laserjet.
If you use the wrong type it can melt or get jammed up in the printer.
05-22-2023 12:56 PM
You didn’t answer my question. Would this printer work with transparent film?
05-22-2023 01:08 PM
If you have questions, feel free to reach out to support.
05-22-2023 02:51 PM
@mrrurball wrote:You didn’t answer my question. Would this printer work with transparent film?
Actually, I did. I told you transparencies are not supported, but you can print on most devices as long as you use a brand intended for the type of printer inkjet or laser.
You didn't specify a specific model. Now you have. TS2532. Use one sheet at a time. Feed through back. Black, reds and purple are the best colors to use. Show up best on overheads, are most legible and easy to read. Purchase high quality transparencies. The majority will tell you if a particular printer brand is supported. Canon, HP, Epson, etc. They also normally tell you what settings they recommend, since most printers themselves do not support paper type: "Transparency"
@Stephen, thanks for jumping in.😀
