05-05-2024
03:43 PM
08:06 AM
James_C
Hello all, I purchased this printer 2 months ago on Amazon. It had been working fine up until recently, where now it does not turn on. I've made sure all of the cords are plugged in, moving to different outlets, etc. It just does not turn on. I have also tried holding the power button down for more than 15 seconds in case the button or something was broken. Is there any saving this printer without buying even more junk that will break within 2 months of purchase?
05-05-2024 04:01 PM
The printer has a 1 yr warranty from Canon. I'm sure they can help with troubleshooting and if warranted a replacement.
Register your device here, and provide proof of purchase. You'll be able to call Canon and work on getting your device replaced.
01-15-2025 07:48 AM
Hi boggington, we recently purchased the same printer through amazon as well and are having the same issues. I've tried new cords, moving the usb to a different port, resetting the printer and nothing. I was able to get it to turn on a couple of months ago by moving it to my pc and then back to the other individual's pc. It will not turn on again now and it happens at least 1x every 4-6 weeks.
Have you had any luck with your printer or any ideas on how to get it to turn on??
thanks, Rose
01-15-2025 10:43 AM
Greetings ,
The printer does not have to be connected to anything except power in order to turn on. If it's plugged into an electrical outlet and receiving power, pressing the power button should turn it on. I suggest you use the information in my post above to contact Canon support.
01-15-2025 11:09 AM
Yes it was plugged into an outlet that has power. Apparently the one I have is defective and I will be getting a replacement. Fingers crossed the new one works good!
03-02-2025 03:10 PM
Hello, my TS202 was doing the same thing. Not powering on. The issue seems to be a poor connection for the power cord box/module to the printer. Remove the power cord from the unit, The power box snaps out and you will see to small blue wires that connect the printer to the power supply. Unplug the connector with the 2 blue wires and reinsert in the power supply. Plug printer back in and test for power now. Hope this Helps!
