12-31-2020 03:45 PM
When scanning a 5 page document, the Canon IJS Scan Utility Lite no longer shows all 5 pages--it only shows three. I was told by customer service to simply click and hold the third page. The problem with this workaround is that once you click and hold the third page, the pagies tend to skip around. I'm not sure what happened, but there used to be a slide bar that enabled users to see all the pages they scanned, as well as to flip the direction of the pages if, for example, a scanned page was upside down. Now, the slide bar appears and disappears, and every time you touch a page (in an effort to see the hidden pages), the order of the pages jumps around and changes. It is frustrating and time consuming to not be able to easily see the pages just scanned. The whole purpose of the scan feature is to create PDFs, but it's so difficult to finalize a PDF without seeing all the pages first. This is making the scanner worthless.
01-01-2021 10:39 AM
This might be related to the size of your monitor or progam window.
Check Scan Results Option:
Canon : Manuals : IJ Scan Utility Lite : Saving after Checking Scan Results
Note: This option is not avaialble in Auto Scan Mode
Scan Results Area:
Canon : Manuals : IJ Scan Utility Lite : Save Settings Dialog
Here you can preview the scanned images before saving. The dialog allows drag and drop for reordering pages if desired. Can you make this dialog bigger? This may increase your viewable area.
01-01-2021 12:49 PM
Thanks. I have two, 22 inch monitors. It's been working fine, but now isn't for some reason?
