PIXMA TR7020a Support code 7700
Ccampbe1
I have gotten an Support code 7700 on my Canon 7020a. It says I'm supposed to turn off the machine and contact the service center.  How do I do that and what is this code?
2 REPLIES 2
MikeTarter
This sounds just like the "ERROR" I got on my MG2522.  I've had two of em - both threw the same B200 "error" message to take it to a service shop.  Every shop I call says "it aint worth repairing", and you cannot buy whatever part to fix it yourself - Canon won't sell you the part. I have a hunch it isn't actually a failure - it's a firmware built-in  "F YOU" after so many pages to force buying another.  I won't - I'm informing all friends and family DO NOT EVER BUY A CANON HOME PRINTER!
DerrickL
Understanding Canon PIXMA TR7020a Support Code 7700
What Does Error Code 7700 Mean?
The support code 7700 on the Canon PIXMA TR7020a typically indicates a problem with the print head or an internal hardware malfunction. This error can arise from several issues, including:
  • Clogged or faulty print head
  • Problems with ink cartridges
  • Mechanical failures within the printer
How to Resolve Error Code 7700
To fix the error code 7700, follow these steps:
  1. Clean the Print Head: Use the printer's maintenance options to clean the print head. This can help remove any clogs that may be causing the issue.
  2. Check Ink Cartridges: Ensure that the ink cartridges are properly installed and have sufficient ink. Replace any cartridges that are empty or damaged.
  3. Restart the Printer: Turn off the printer, unplug it for a few minutes, and then plug it back in and turn it on. This can reset the printer and clear temporary errors.
