PIXMA TR4720 doesn't print well
RogerBlair
I run Windows 11 Pro on a Dell Inspiron laptop. I recently got a PIXMA TR4720 printer/scanner/copier. The printer worked fine until I replaced the black ink cartridge; then things went bad. I'm enclosing links to the Alignment Sheet, the Nozzle Clean report, and a test sheet I printed showing the problem:
Alignment Scan: https://www.dropbox.com/scl/fi/61eae735sj1hhivmjlbrk/Alignment-Scan.pdf?rlkey=01fpqnezojksye0wzlfl67...
Nozzle Clean: https://www.dropbox.com/scl/fi/j9b8w0yoomc96teln8fef/Nozzle-Clean.pdf?rlkey=bxp8k95unkcdeg1o8a04u14y...
Printed Document: https://www.dropbox.com/scl/fi/3wm89iuoq9mh74zp7dpjt/Peinted-Document.pdf?rlkey=7gtwpmbw5r5tdi3dfxsa...
How do I fix this?
3 REPLIES 3
SignifDigits
Thank you for participating in the forum.  Many kudos and thanks for providing the prints.  It seems you have already diagnosed the issue as the new ink cartridge.  I would suggest you coordinate a replacement with the provider - hopefully that was Canon.  If so I'm sure they would be happy to support you by calling Canon USA support, Phone number: 1-800-OK-CANON (1-800-652-2666) Monday to Friday, excluding holidays.
If it is not a Canon cartridge, you can certainly try to get support from your cartridge provider, but since they sent you a cartridge that fouled your printer I suspect you could get less than a fully satisfactory result going down that path.  I suggest that you get a Canon cartridge and contact Canon directly for assistance in cleaning up the mess.  It looks to me like you may need to physically clean the print head and run a number of nozzle cleanings to get the mess cleaned up.
Plus>> Canon imagePROGRAF PRO-1100 Printer. My photos are edited using no Adobe products.
(Written with a VERY red face!) It turns out the problem was operator error--I'd forgotten to remove the tape from the print head of the cartridge; I removed it, and all is well.
Sorry for the hassle.
SignifDigits
Yikes!!!  I should have thought to ask that.  Many years ago when I was working more in IT we always asked "is the computer plugged in?"  It was surprising how often the answer was "Uh-oh".  I even did it myself one time.  So, thanks for passing the info along and don't beat yourself up too much!  Life happens.
