PIXMA TR4720 Fixing Frequent Paper Jams and Print Quality Issues
harmankandhari
Hi Everyone,
I'm Harmandeep Singh Kandhari, Health and Wellness Motivator. Now, I want to know about what troubleshooting steps are recommended for resolving frequent paper jams and faded prints on a Canon PIXMA TR4720? Could this be related to driver updates, ink cartridge alignment, or roller maintenance?
Thanks,
DerrickL
All the above.
Common Causes of Paper Jams
  • Incorrect Paper Loading: Ensure paper is loaded correctly in the tray.
  • Paper Type: Use suitable paper sizes; avoid A5 for documents with photos or graphics.
  • Obstructions: Check for any foreign objects in the paper path.
Steps to Resolve Paper Jams
  1. Check for Visible Jams: Open the paper output tray and check for jammed paper.
  2. Remove Jammed Paper:
    • Pull out the jammed paper slowly to avoid tearing.
    • If not visible, check the feed slot and rear cover.
  3. Restart the Printer: If the paper is stuck, turn off the printer, then turn it back on to see if it ejects automatically.
Improving Print Quality
Common Print Quality Issues
  • Blank or Faint Prints: This may indicate low ink levels or clogged print heads.
  • Blurry or Streaky Prints: Often caused by dirty print heads or incorrect paper settings.
Steps to Enhance Print Quality
  1. Check Ink Levels: Ensure cartridges are not empty or improperly installed.
  2. Clean Print Heads:
    • Print a nozzle check pattern.
    • If issues persist, perform a deep cleaning of the print heads.
  3. Adjust Settings: Verify that the correct paper type is selected in the printer settings.
2 REPLIES 2
DerrickL
All the above.
harmankandhari
Thanks DerrickL for the great reply! Really appreciate it.!!
Thanks and Regards
