01-16-2025
12:54 PM
12:57 PM
SamanthaW
I need help with my TR4520 printer. it won't print. i kept getting error message on the que.
01-24-2025 05:44 PM
Patrick, Canon Expert, i followed your instruction and pressed "nozzle check" TR4520 printed the test print and there is no "error" appeared. I am using the printer wirelessly.
01-16-2025 12:58 PM
Hi there!
Just to make sure the community has enough info, can you please let us know the operating system on your device you're trying to print from and the specific error message you're receiving.
If this is a time sensitive issue, please check out your support options on our website HERE.
01-16-2025 01:45 PM
i'm using either my hp or dell laptop. everytime i print to the canon TR4520 printer, error printing shows on the display print que.
01-21-2025 04:03 PM
Hi CanonSD,
When you turn your PIXMA TR4520 on, does an error appear on the display?
Also, are you using your TR4520 wirelessly?
or with a USB cable?
01-21-2025 05:16 PM
1/21/25
Patrick,
no error appear on display. it only says color ink low. and when i print the que in my laptop says it's printing but takes forever and eventually says error in the que not in hte canon printer itself.
01-24-2025 01:42 PM
1/24/25
wirelessly.
01-24-2025 01:45 PM
1/24/25
and everytime i print to the canon TR4520 printer, "error printing" shows on the display print que in my laptops printer setting.
01-24-2025 02:11 PM
Hi CanonSD,
Let's do a test of your printer:
1. Please press the wrench and screwdriver button on your TR4520 one time
2. Repeatedly press the right arrow key to select Maintenance and press the OK button.
3. Select Nozzle Check and press the OK button.
Did the test page print? If not, what error appears?
or are you using it with a USB cable?
01-24-2025 05:44 PM
