PIXMA TR4500 Series - Yellow Light
Pferucci
I have a TR4500 Series Printer It has worked fine for 2 years, But now there is a Yellow Light on, it is not blinking, the Power Button light is on, if pushed it does not turn off, there is no light on on the LCD , if you push any button nothing happens, if you open the ink door the ink does not slide like it used to when opened and i have unplugged the unit waited 5 mins then plugged back in once this is done the yellow light comes back on and nothing else. i then push the power button that light comes on, but yellow light still on and nothing functions. Help!!!!!!!!
2 REPLIES 2
Moderator
Moderator
Thanks for joining the conversation, Pferucci!
So that the Community can help you better, we need to know exactly which Canon printer model you're using in the PIXMA TR4500 series. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
Hi I'm having exactly the same problem I hope you can help 🙂
