11-12-2025
02:48 PM
08:19 AM
James_C
Hi, there! I have used this printer only a couple of times. When I noticed that the black ink wasn't printing, I ordered a new Canon OEM ink cartridge (Black). Installed it, did a print test and it only printed the COLOR ink (which is also Canon OEM ink).
I ran the Clean Head and it didn't help. I received an Error message stating "Support Code 1600, The ink may have run out..." How's that possible when I just replaced it?
I ran Deep Cleaning and the print on that looked worse than the first print from cleaning the head.
I then ran Auto Head Alignment, received another Error message stating, "Support Coder 2500, Auto Head Alignment FAILED."
I'm totally frustrated now because nothing works.
Questions: Is there a way to clean the Printhead manually? What should I use to clean it with? Are there any other suggestions besides using the Printer to clean the Printhead? I don't understand why the printhead might be clogged. I barely used this Printer, had to replace the black ink before it even ran out, and it just won't print Black ink.
Many thanks for the replies!
11-14-2025 01:28 PM
Hi BlackHeartNY,
Please contact one of Canon's Technical Support Representatives via phone or chat. To contact a Technical Support Representative, please use the link below to log into your My Canon account:
https://mycanon.usa.canon.com
Once logged in, click on your PIXMA TR150 and then click on the Product Support button. When that page loads, click on either the Phone Support button or the Chat Support button to access support. A Technical Support Representative can determine the cause of the issue and resolve it or provide you with your available service options.
11-14-2025 01:28 PM
Hi BlackHeartNY,
11-14-2025 01:41 PM
Thank you, Patrick, for replying to my query. Much appreciated! I willl definitely try that.
