04-20-2020 07:36 AM - last edited on 06-14-2024 01:42 PM by Danny
how can i stop printer from printing photos on small pieces of paper and print on 81/2x11 paper only
04-20-2020 08:20 AM
Welcome to the Canon forum!
So that the Community can help you better, we will need to know what model Canon
equipment you are using. Any other details you'd like to give will only help the Community better understand your issue. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE.
04-20-2020 09:31 AM
04-20-2020 06:45 PM
04-20-2020 07:22 PM
When you click Print a screen should pop up with different settings. You might have to click on Preferences and then make sure the paper size is set to Letter 8.5 x11 and the paper source is set to Cassette (lower).
05-05-2020 02:24 PM
Hi Rhea,
To select the proper paper size, you will need to change the settings on the device you are printing from. If you are using a computer, you will need to change the settings from your print screen. If it is from a phone or tablet, you will need the correct app installed. To provide the proper steps to change the paper size, we will need some additional information. If you can reply to the message with the information below, we can provide assistance.
