12-04-2012
07:58 PM
04:01 PM
Suddenly error code B200 no explanation in manual have canon pixma mx850
12-11-2012 11:44 AM
Hello grampatex.
Please try the following to see if we can resolve your issue:
1. Open the cover of the printer.
2. Remove all ink tanks from the printer.
3. Lift up the gray locking lever on the side of the ink tank holder.
4. Gently remove the print head from the carriage unit.
5. Place the print head back in and lock the lever down.
6. Place all of the ink tanks back in the printer.
7. Close the cover and turn the printer off.
8. Unplug the power from the printer. Leave the power unplugged for about 5-10 minutes.
If the error continues to persist, please contact our support group using the "Contact Us" link below.
03-30-2013 06:31 PM
The message to repair my MX850 with a B200 error code was to first remove and replace the ink tanks. When I open the top the module that holds the ink tanks remains on the far right of its track where the tanks cannot be accessed. Normally when I lift the lid to replace a tank, this module moves to the center where it can be accessed, but it is not doing this. Suggestions?
04-02-2013 09:08 AM
Hello Rick_Ridgeway.
1. Turn the printer off.
2. Unplug the power from the printer for at least 5-10 minutes.
3. While unplugged, remove any paper from the unit.
4. Double check for any obstructions found in the unit or paper paths.
5. If no obstructions are found, plug the power back in and turn the unit on.
If the B200 error persists or the tanks cannot be accessed , please contact our support group using the "Contact Us" link below for additional assistance with this matter.
05-15-2013 07:44 PM
This is the same generic answer that Tech Support sends. Would be nice if Canon's error logic would be more specific.
My MX860 was getting this error and I tried all the suggestions for cleaning the printhead without success. Since I actually like this priinter and it is setup for my windows and Linux, I took a chance and found a new printhead on EBAY for $50. This fixed the problem.
07-16-2013 01:43 PM
08-09-2013 05:40 PM
I am having exactly the same problem as Rick. Tried turning the printer off and unplugging for ten minutes. When I plugged it back in and turned it back on, the error code immediately returned. Now What?
08-10-2013 11:24 AM
08-10-2013 04:08 PM
08-26-2013 11:31 AM
Okay; did all of those steps twice.
NADA, no good, still get flashing alternate between orange alarm light and green copy button. Does it 10 times then repeats. Where's decoder to identify what 10 consecutive flashes mean?
